Newbie needs help!
Old May 31, 2003 | 07:25 AM
thadon617's Avatar
thadon617
Default Newbie needs help!
Hi guys Im a newbie and I wanna have a desent speed im my 97 GSR teg in my area. Can you guys tell me if this is a good setup or is this just a waste of money. I have $7000 to invest in it( I know it'll cost a tad more than $7000 but please give me your honest opinions about this setup. Thanks in advance.
1. Vortech Supercharger
2. Apexi GT SPEC EXHAUST MANIFOLD
3. Apexi Dunk Cat Back Exhaust system( I already have but not in yet)
4. E.C.U./E.M.S from - AEM
5. Cams/Pulleys from - AEM
6. Fuel Rail - AEM
7.Fuel Rail Presure Regulator - AEM
8. V2 CAI( Is it worth it?) - AEM
9. DIGITAL VTEC AFC - Apexi
10. Type R Rear & Front strut Bars.
11.MSD ignition Kit
12. Spark plugs( please provide your opinion on which one)
Please feel free if Im missing anything else that should be done so i can add it or increase my budget a lil more.
Old May 31, 2003 | 04:48 PM
R92680's Avatar
R92680
if you get the AEM plug & play unit you wont need the VAFC unless you want to change your cross over
my 2 cents
get the AVC-R
Old May 31, 2003 | 05:06 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
You'll be faster if you replace Vortech with either a JRSC or off-the-shelf turbo component. I was considering the Vortech unit awhile back but it was more for the linear/predictable power gains versus overall blazing straight-line speed. I'm also pretty sure you can't use the AEM V2 with the Vortech.
Shingo
Old Jun 1, 2003 | 01:09 AM
95tegRS's Avatar
95tegRS
jackson racing!!, these people's have been tuning Honda's for a long time!!
Old Jun 1, 2003 | 06:31 AM
newgsrdriver's Avatar
newgsrdriver
Youve got a lot ot research ahead.
A bunch of those components cant be used in conjunction with each other, or are totally worthless.
My advice? Read a TON about SC's and turbos. Dont rush into things, and dont jump into conclusions when you read something and *think* youve made your decision. Take your time, research both routes and decide what you want.
THEN start putting together a list, step by step, of what you want to do with it.
Old Jun 1, 2003 | 09:27 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
:werd:
Old Jun 1, 2003 | 12:36 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I think you should attack one area of upgrades at a time. Wheels/tires, suspension, brakes, engine are all different. Plan to do each on its own rather than making a budget and thinking about which ones you can afford.
my 2 cents
get the AVC-R
The AEM EMS can change VTEC crossover so the V-AFC would be totally redundant, and the AVC-R is an electronic boost controller.
Old Jun 2, 2003 | 07:33 AM
yeer's Avatar
yeer
All Motor ONLY!!!!!!!
JRSC is alright. It really depends on what you want in the car. JRSC is more for low end and mid range power. while the vortech is just all topend. if u just like something a little faster for the streets and not really into drag racing at the track then go with the JRSC. u will make alot more power with the vortech than with the JRSC.
as far as other mods, u should look into hondata, cheaper than aem ems and apexi fc.
also if u run the JRSC, u will need a header with short and fat primaries with a 2.5'' collector. ive made 16whp with the kamikaze 4-1 header and testpipe.
also u dont want to run a cai with the JRSC. u will get all the air you need from the charger so u will need to look into a intake will good throttle response.
look into a fuel pump instead of fuel rail. waste of money, plus for the plugs i used the denso iriduim one stage colder.
Old Jul 14, 2003 | 09:05 PM
rwsk8er87's Avatar
rwsk8er87
i was wondering too if a jackson racing or vortech s.c. would be better for some street racing, some track, and just to have a fast fun to drive car. what is your guys opinion on what i should get?
Old Jul 15, 2003 | 04:53 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
:down:
