Lower Tie Bar
I bought a lower tie bar for my 2000 gsr and when I went to install it, my stock rear sway bar was in the way. Did I get the wrong one or do they even make one for the GSR? If they do make one could you please post some websites for a good one, I would also like a front tie bar also.
Thanks
Thanks
Originally posted by Skelly_GSR
Hey nice car Legend. CW and blades, what more to ask for? Anyway Im going to make my own tie bar, its really easy
question 1. - What tie bar did u purchase?
question 2. - If a tie bar mounts through the LCA joint bolts, how come your stock sway bar is getting in the way?
question 3. - Are your ABS sensor lines getting in the way?
question 4. - Do you have any pictures you can post?
Good luck!
Good luck!
DB Squad
Integra Forum Moderator
DB Squad
That bar, was probably designed for a Civic 92-95. Although 94-01 integras and 92-95 civics share the same subframe, some civics did not come with a rear sway bar. Try pulling out one of the LCA bolts, and taking apart your tie bar brackets from the bar, and just try it with the LCA bolt in with the tie bracket by itself.
DB Squad
DB Squad
