headlight condensation
Old May 8, 2003 | 06:01 PM
rsmith4390's Avatar
rsmith4390
Default headlight condensation
Hey new to the forum. I have the front right side low and high beams that is starting to develop condensation. I check the rubber tube vent and it appears to not be clogged. Any suggestions? Thanks
Old May 8, 2003 | 07:48 PM
XSrcing's Avatar
XSrcing
use a 1/16" drill bit and drill a couple holes on the bottom, near the rear of the plastic housings. this will solve your problem, and from experience, won't cause any more problems.
Old May 10, 2003 | 07:15 AM
LT's Avatar
LT
The deer had to die!
take out the headlight assembly and inspect for cracks in the housing. Also, check the seals around the lens for any breaches. When I had this problem, I put the headlight assembly under a heatlamp to evaporate all the water in there. But it came back (i have a fairly large crack in the top that keeps undoing my sealant), so i'm just going to drill.
Old May 11, 2003 | 07:03 PM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
you can try and reseal all around the outside of the headlight assembly. that is what i was goin to do to mine, but i had a minivan come through my front end so i just had the whole front end replaced.
