97 gsr engine on 96 integra
Old Apr 8, 2003 | 06:02 PM
bori28's Avatar
bori28
Default 97 gsr engine on 96 integra
i bought a 96 ls and put a 97 gsr on it.but i still cant figure out how to hook up the vtec and the sensors.im getting check engine light.still using ls hardness and odb2 ecu.i would appreciate any help.i have search the whole website and still cant find anything
Old Apr 9, 2003 | 10:42 AM
JimBlake's Avatar
JimBlake
Don't you need an ECU & wiring from a GS-R? Otherwise your LS ECU doesn't know you have VTEC or IAB. Or a knock sensor.
Old Apr 9, 2003 | 03:31 PM
bori28's Avatar
bori28
i do have th gsr ecu but lshardness
Old Apr 9, 2003 | 10:08 PM
AP2's Avatar
AP2
Moderator Alumni
Did you add a wire for your VTEC?
Old Apr 10, 2003 | 07:51 AM
eclipse spanker's Avatar
eclipse spanker
you need to swap your computer also, for a gs-r coputer, that is programmed to for the knock sensor, and for vtec activation.
Old Apr 10, 2003 | 09:17 AM
JimBlake's Avatar
JimBlake
Then you need to make up all the wiring connections that are missing from the LS harness. Like the VTEC solenoid, VTEC oil pressure switch, knock sensor, IAB vacuum valve... & whatever else I'm forgetting.
Old Apr 10, 2003 | 04:06 PM
bori28's Avatar
bori28
i need find out what wires are for the iab valve.and anything else
Old Apr 13, 2003 | 01:22 PM
JimBlake's Avatar
JimBlake
Are both '96 & '97 OBD-II? So if you've got a Helm shop manual for your '96, it's got all the wiring you'll need for the '96 B18C1. I bet there's hardly any difference in the wiring between '96 & '97??
