Nitrous Question?
Originally posted by Chrgsr96
You unbolt 3 bolts on your distributor and move it either forwards or backwards to retard or advance the timing. You will want to retard the timing. I'm pretty sure I explained that right.
When you loosen the bolts, the distributor can rotate. Rotate the distributor clockwise to retard the timing. You will also need to short out the service connector by the ECU. Here's a great link for you: http://www.c-speedracing.com/howto/timing/timing.php
The link works for me.
