Pics of my Type R Turbo!
Old Mar 18, 2003 | 07:31 PM
ls/vtec-crx's Avatar
ls/vtec-crx
Originally posted by txhatch
Is it tuned at all? That seems kinda low.
Yeah we tuned it on the dyno with hondata.
Old Mar 18, 2003 | 07:38 PM
ls/vtec-crx
Originally posted by 01 Tight R
hey what up i have 01 itr and am thinking of turboing it only 7-10 psi do you have any suggestions? I know the compression is high I dont wanna gernade the engine!! I know a metal head gasket will help and a jns knock sensor----any other thoughts...like how you did your oil lines and or water???
I'm running a SCE Copper Head Gasket to lower the compression .093 thou thick which is pretty much a 3mm gasket. You must o-ring the head for it to properly seal.
And then for engine management i highly suggest a hondata S200 system. There must be a authorized hondata tuner in your area to tune it properly. I am safely running 8 psi.
For an oil line you just have to run a steel braided line from your oil pressure sender to the turbo.
For more info check out www.speedtechracing.com just call the toll free number and ask for allan.
Old Mar 18, 2003 | 07:41 PM
ls/vtec-crx
Originally posted by RB
what the hell?
you said it would be no less than 280, and up to 330?
Ya we were really surprised too but we pulled out the turbo and checked the wheel trims. TOO SMALL. So now i have a new turbo and manifold coming. So hopefully next time i will pull some better numbers and next time i'll have it on video for you guys. Forgot it the last time.
Old Mar 20, 2003 | 05:13 PM
Teg711's Avatar
Teg711
Purge This...
nice choice on everything, i heard the drag kit is good, lemme know what you think. if i get hondata(s200 handles up to 30lbs boost) that's all the stand alone engine management i need right?
Old Mar 20, 2003 | 05:16 PM
kabob's Avatar
kabob
As long as you have an OBDI ECU to mate to the s200 and get it properly tuned, then yes.
Old Mar 22, 2003 | 10:07 AM
crucial Si's Avatar
crucial Si
Banned
nice car, to bad its turboed, you can produce that much h/p by all motor...oh well.
Old Mar 22, 2003 | 02:33 PM
00itr950's Avatar
00itr950
looks very nice, but why not a gsr instead? or do you plan to use the car for what it is designed for? I hope you don't take this the wrong way. Looks nice ...........
Old Mar 25, 2003 | 04:14 AM
loodboi's Avatar
loodboi
هونده بريلود
Thats a clean mothafu'cka!!
btw, i love the jdm front end!!
Old Mar 25, 2003 | 06:01 AM
Singhg83's Avatar
Singhg83
BALLIN'
i liek ur mugen bumper bud
Old Jun 24, 2003 | 07:16 PM
chyna509's Avatar
chyna509
Sweet car.
