obdII to obdI jumper q's
Old Feb 27, 2003 | 08:36 AM
mikesudds's Avatar
mikesudds
supa dupa member
Default obdII to obdI jumper q's
i have a 99 integra that i finally got back from the body shop...
(small accident)
since i got it back
i put on obdII to obdI
jumper harness on the car w a 94 ls ecu
and put a test pipe where the cat was then put a high flow resonator on the car...
my question to you all is now when i crank the car up i get a real rough idle...
and the car will act like it is going to die...
some times the car takes a little while to even crank..
after it is running and warm it is fine...
i have searched for this topic but have found nothing....any help would be greatly appreciated...
thanks
mike
Old Feb 27, 2003 | 08:50 PM
mikesudds's Avatar
mikesudds
supa dupa member
anyone???
i replaced the spark plugs tonight
it's still doing it
mike
Old Feb 27, 2003 | 10:59 PM
dubcac's Avatar
dubcac
I
Running too rich maybe?
Old Feb 28, 2003 | 04:46 AM
gsr2k's Avatar
gsr2k
Default Re: obdII to obdI jumper q's
Weak battery?
Old Feb 28, 2003 | 02:00 PM
mikesudds's Avatar
mikesudds
supa dupa member
you know what i just thought about....at about 3500 rpm's my car's lights do get just a little bit brighter...
would a weak battery really have that effect on the car???
mike
Old Feb 28, 2003 | 02:22 PM
gsr2k's Avatar
gsr2k
It could. In my original message, I qouted the things that stood out as posible results of a bad battery. Get it checked out - I think it's supposed to be 400+ CCA (cold cranking amps). This is differnet from the regular current and some shops can't test the CCA.
The alternator might also be on the decline, so you may want to have that checked as well.
Let me know what happens.
