Clutch ??
Old Sep 4, 2009 | 05:15 AM
gingas's Avatar
gingas
Default Clutch ??
Hey how's it going. I'm in the process of looking at some clutches. It's for a 98 GSR. It'll be a daily driver but, I'm looking at a Exedy stage 1 clutch. Can I just get the clutch & have my oem flywheel resurfaced or would it hurt getting a lightened flywheel. If so what brand flywheel do you guys recommend & what's some good places to order.
I have 171K on orig. clutch. I just want a little more bite than stock but not a heavy clutch pedal for everyday traffic you know what I mean...
Any advice welcomed. Thanks..
Old Sep 4, 2009 | 05:45 AM
Spec R's Avatar
Spec R
stage 1 exedy with stock resurfaced flywheel is nice. with 171k i'd also get a new clutch master and slave cylinder. its always best to get the "least" amount of clutch that is needed for your car. anything more than whats needed just adds drivetrain shock and wears out parts unnecesarily.
DB Squad
Integra Forum Moderator
Old Sep 4, 2009 | 06:59 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
When I replaced mine last year, I went with an exedy stage 1 and a fidanza flywheel.
Old Sep 4, 2009 | 07:30 PM
cruzalekz's Avatar
cruzalekz
act clutch
Old Sep 5, 2009 | 12:41 AM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
I went with exedys stage 1 clutch and love it. Since my car is basically stock it works great at the track and I personally haven't noticed any "Heavier feel" to the clutch in daily driving.
Old Sep 5, 2009 | 06:05 PM
gingas's Avatar
gingas
AcuraLsSE when you went with the stage 1 did you keep your stock flywheel . Also, did you change anything else.
Old Sep 6, 2009 | 10:48 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
I'm using an Exedy stage 2 with an ACT Prolite flywheel.
Old Sep 10, 2009 | 01:26 PM
Difussion3's Avatar
Difussion3
Touge
Do you guys think an Exedy stage 1 with an OEM ITR Flywheel will be a nice setup for a daily driven 99' GSR?? I want a little extra kick when driving compared to the OEM clutch/flywheel. Also, I'm at 108k miles, should my master and slave clutch cylinders be changed?
Old Sep 10, 2009 | 01:56 PM
Spec R's Avatar
Spec R
as long as you dont pay the type R tax on the ITR flywheel you should be fine. yes, change the master/slave cylinders.
DB Squad
Old Sep 15, 2009 | 07:05 PM
gingas's Avatar
gingas
Are either master & slave cyl. expensive?
