Turbo for a GSR
Old Feb 6, 2003 | 12:58 AM
exzeltus's Avatar
exzeltus
Originally posted by Shingoblade-GSR
It will cut your engine life (maybe not in half) just due to increased wear and tear. But this issue usually comes up with supercharging.
People will tell you boost is boost and that with proper tuning you'll be fine blah blah blah but the bottom line is that if you want to go fast you'll need to work your components harder. What do you want your car to do?
Shingo
What did you mean w/ "But this issue usually comes up with supercharging."?
I didn't quite follow that sentence.
Old Feb 6, 2003 | 01:07 AM
JustChilln345's Avatar
JustChilln345
Originally posted by tehsuxGST
psst, stealths arent DSMs. only eclipse lazers and talons
if u pop the hood on a stealth u will see nothing but mitsu stickers everywhere...trust me i was just as surprised the first time i popped it open.
Old Feb 6, 2003 | 03:35 AM
pomansouth's Avatar
pomansouth
pssst. the mitsu 3000gt and dodge stealth are the same exact car so i would call it a dsm. its just like that isuzu rodeo and honda passport. cept honda got screwed on that one and now they dont do it anymore i dont think.
Old Feb 6, 2003 | 05:18 AM
JustChilln345
thank you pomansouth. i dont even own an integra yet, still trying to pay off the stealth (impulse buy, wut can i say?), but after its paid off im sellin it and gettin me a tegy. i just think its good to get these issues out of the way so that i know wuts coming down the road.:thumbup: :naughty:
Old Feb 6, 2003 | 05:19 AM
ShaolinLueb's Avatar
ShaolinLueb
i made a thread about this a while ago, do a search that was pretty useful to me.
Old Feb 6, 2003 | 08:18 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Let's keep it to the topic.
In the most general sense, adding a turbo to any motor is going to introduce more heat and cause higher output which increases wear.
You can make a reliable turbo motor, but yeah. I would say that this thread is a very general question.
Old Feb 6, 2003 | 10:24 AM
hakjai's Avatar
hakjai
i had previously had a turbo ls motor...after blowing that one i had an option of buying another ls motor or getting the b16a for 50 bux more..smaller engine with vtec...when ur boosting and vtec kicks in on the highway theres nothing like it, it jus pulls hard..but i went to a smaller engine so im experiencing some problems with torque but if u decide to go with the gsr u should be fine =)
hope it helps
Old Feb 6, 2003 | 03:30 PM
tehsuxGST's Avatar
tehsuxGST
sorry for straying off topic again but DSM is diamond sport motors which means parts manufactured by the joint between chrysler and mitsubishi. the earlier eclipse talons and lasers actually had the 3 letters DSM in the engine bay (1991-1995) which is where the name originated, even though they are absent from the later models the same 3 cars still are considered "DSMS". the 3Ss are badass cars, just not DSMs.
back on topic, what is the maximum amount of boost that stock internals on a gsr will allow? 6-7?
Old Feb 6, 2003 | 03:50 PM
Sportmode's Avatar
Sportmode
according to Corkey Bell (author of maximum boost)
"Certainly a turbo will affect engine wear...If you drive vigorously but with some respect for the equipment, you can expect about 90% of normal engine life."
Basically the more power you have the more wear and tear you put on the motor. With a turbo setup you most likely wont be in full boost at all times. A turbo is only going to give you full boost under heavy acceleration. For example My GSR revs at about 4000 rpm at 80 mph with no turbo. If i had turbo im pretty sure that i could still go 80mph at 4000rpm without reaching full boost. So a turbo isnt always putting very much wear on your motor, only when you are driving hard.
(corect me if im wrong i havnt quite finished "Maximum Boost" yet )
Old Feb 6, 2003 | 03:53 PM
Sportmode's Avatar
Sportmode
"what is the maximum amount of boost that stock internals on a gsr will allow? 6-7?"
there is really no right answer to this question, because it all depends on how you tune your setup. With forced induction, tuning is the most important thing you can do. I would say with minimal tuning anywhere from 6-8 would be acheivable for a reliable setup.
