Multiple Questions.
Have Multiple Noob Questions About my 2000 Acura ITR.
1. If i Change my Final drive to a 4.9 FD should i change cam gears / shafts as well? Any Information would be extremely helpful
2. Wanted to add some Forced Induction and have heard multiple arguments between JRSC and a Turbo. So i'm leaning toward a turbo. Any suggestions?
3. What else can i do to add torque? Still learning about the car, So Any information would be helpful
#1: A more aggressive cam would be helpful, but it certainly isn't mandatory.
#2: Consult the FAQ. While the big MP62 blower used in the JRSC for the ITR is a nice unit, you will ultimately get more power per dollar with an appropriately sized turbo.
#3: See #2. Granted, nitrous oxide is also an option to FI. But if you're considering a JRSC, I assume you're worrying about smog legality as well.
-TheOtherDave
#1/2 - Thank you very much. So currently i'm on a low budget, so i'll probably start off with the FD andt hen move on to the Turbo, i hear Garrett is a good manufacturer.
#3 - I'm actually a bit scared to add a nitrous system to my car. Mostly afraid of completely wrecking my car injecting it wrong or something. LoL.
Are there any Build threads that start from a Stock ITR into a monster? lol.
Also dave,
I hear a lot about drilling the engine from a 1.8L to a 2.0L can you tell me how and why people do this? or should i look in FAQ?
Also dave,
An upgraded final drive is a very good start.
Nitrous is what you make it.. It can be safer than turbocharging, and it can be more dangerous. It depends on the tune. I suggest Hondata (S200/300) since they have switchable maps for nitrous on the fly.
Because you're on a budget, you're going to have to make some choices. Either you piece together a turbo kit, or you buy a lower end one. You can piece one together for pretty cheap, get a decent manifold (not eBay!!) a turbo like a 14b from a DSM, etc. I suggest looking around online and doing research. One thing you cannot skimp on is the tune, at all. A shitty tune shows, and you pay several times more in the long run.
As for 'drilling', you mean boring. I highly suggest NOT boring out stock sleeves. If you want a 2.0L block, get yours sleeved, or buy a sleeved block. Good companies are; AEBS, Darton, Golden Eagle, etc.
As for build threads, there's not many here. Check out Team-Integra.net. The forum as far as a community sucks, but there's some really good info in the articles section.
-pslsnakes
Thanks alot. I'll look into the Hondata and nitrous.
Most likely will lay off the um, boring on the engine to get a 2.0L.
So a Tune and a Turbo and a FD will be my start i guess.
Thanks a lot and i'll check out that website!
Was just curious w/ the ITR you want boost. Most people tend to stay all motor w/ the ITR. Usually people get a GSR if they plan on boosting.
Nice car though. So which color you have black or yellow?
-gingas
the reason that most people boost GSR's instead of ITR's is because the engine
can take it better . right?
It's still safe to turbo my integra tho correct?
And Yellow
with black carbon fiber hood
And Yellow
A GSR doesn't 'take it better', they're both completely the same. the only difference between a GSR and ITR is the tranny, the head is a factory ported B16 head, slightly more aggressive cams and a better valve train.
Oh, and post pics of your caR
Without getting new pistons and rods and all that, 220ish to the wheels is very doable. Get a good intake like a Comptech, a good header like Hytech, RMF, Kamakazi, etc. Some good cams, I like Crowers, and Toda, and a good exhaust as well as a tune. To tune, you're going to need to convert to OBDI. To do so you need a OBDII to OBDI jumper harness, and an OBDI ECU, such as a P28 or P72.
