swaybars
Old Jan 30, 2003 | 09:15 AM
matty1821's Avatar
matty1821
Default swaybars
How much of a difference does a swaybar w/built in lower tie bar compare against just a normal sway bar?
ex (suspension tech speedtech vs. skunk 2)
Old Jan 30, 2003 | 10:16 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The subframe which the sway bar mounts to can flex when subjected to the forces of a sway bar bolted to it. It's not so much of an issue that the subframe will break, just that if the swaybar is flexing the subframe instead of pushing on the lower control arms then you have less of an effect. Adding a tie bar stiffens up the subframe which provides a more solid mount for the sway bar to work off of.
Old Jan 30, 2003 | 01:14 PM
blazinxracer's Avatar
blazinxracer
damn that sure cleared up ne ?'s i had
thanx
ne thing else that ne one would like to add???
:thumbup:
