Timing HELP
Old Feb 22, 2009 | 01:01 AM
Eddog85's Avatar
Eddog85
Default Timing HELP
Hello i was wondering if the timing position is the same for all B18 motors Like B18A1
B18B1
B18C1
or is there a diffrent way to time all these motors. Im talking about the mark that you line up when doing the timing. If they are diffrent dose anyone have the diagram for a B18A1 timing position.
Old Feb 22, 2009 | 02:37 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
No, timing is not the same for all motors.
Take a look at this, and while you're at it, join the forum. A LOT of great info and articles.
Old Feb 25, 2009 | 09:24 AM
cruzalekz's Avatar
cruzalekz
match the white line with the pointer.
hand crank the crank pulley about 5 times and see if the white mark ends on pointer and the two cam sprockets in the up position @ #1 piston at tdc. if it does then your good. if not line it up and do it again.
ps spin the crank pulley in the appropriate direction only.
Old Feb 25, 2009 | 09:32 AM
Lynxs1981's Avatar
Lynxs1981
If you are asking about camshaft and belt timing, then yes it's the same.
Old Feb 25, 2009 | 02:59 PM
cruzalekz's Avatar
cruzalekz
well, i think thats what he was asking., lol
Old Feb 25, 2009 | 07:11 PM
Lynxs1981's Avatar
Lynxs1981
Well let's not forget ignition timing.
Old Feb 25, 2009 | 08:15 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
that's what I thought at first, because crank/cam timing is pretty fool proof to mess up or not know how to do.
Old Feb 26, 2009 | 12:41 AM
Eddog85's Avatar
Eddog85
Well thanks im talking about the bottom one i think its the oil pump. But i think theres two with line dose it matter which one.
Old Feb 26, 2009 | 07:59 AM
Lynxs1981's Avatar
Lynxs1981
Ok, well you should have a red and a white mark in the crank pulley. When you are setting camshaft timing use the white mark. When setting ignition timing, use the red mark
Old Mar 2, 2009 | 06:55 PM
Eddog85's Avatar
Eddog85
o right i did it. but my car seems to want to stall when i turn it on. But it dosent happen all the time only somtimes. It runs good and everything. it usally goes away if it step on the gas. Dose anyone know what i messed up.
