94 ls motor [Which ECU?]
Old Feb 9, 2009 | 01:47 PM
Ls Fritz's Avatar
Ls Fritz
Fresh 2 da Game
Default 94 ls motor [Which ECU?]
i am running a 94 ls with a gsr ecu. i know it will work but i am trying to make it right .
removing the v tec from the ecu is one way but what is the correct ecu for this motor.
thanx for yall's help
Old Feb 9, 2009 | 03:46 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
There is absolutely nothing to gain from running a GSR ECU in a stock LS Integra.
You cannot "remove the VTEC" from the ECU either.
Purchase a P74 or P75 ECU that matches the year/obd of your car/engine.
And before you start messing around under the hood, do your research first.
Reading the Integra FAQ is a good place to start.
Moved to Integra / ITR (with redirect)..
Old Feb 10, 2009 | 03:07 AM
Spec R's Avatar
Spec R
i'm with Dave.
DB Squad
Integra Forum Moderator
Old Feb 10, 2009 | 05:12 AM
Ls Fritz's Avatar
Ls Fritz
Fresh 2 da Game
thanx for the help guys
i knew it was a p 7somthing i just was not sure witch was the correct #
Old Feb 10, 2009 | 10:08 AM
Spec R's Avatar
Spec R
oh yeah make sure it matches your transmission (auto vs manual)
DB Squad
