Antenna is stuck
Old Jan 7, 2003 | 01:13 PM
integRacer05's Avatar
integRacer05
Default Antenna is stuck
my antenna is stuck on my 95 Integra Ls, i took it to a shop and they said it'd be $125 in parts and work, and i was wondering if neone could tell me how to do it myself since i dont' want to pay that much, thanks
Old Jan 7, 2003 | 01:51 PM
gregz93integra's Avatar
gregz93integra
Banned
dude its really easy...assuming you mean it stuck in the up position.
there's 2 ways to fix the prob..
1st the easy way. take a rag and put over the top of the antenna, and lightly hit it with a hammer until it goes down all the way or almost all the way. this is what i did, and I can still pick up any radio station.
OR..if you want to Replace it, use that "certain tool" for removing the antenna surround, then open you hatch, take off the side paneling, remove the bolts and replace. and there way cheaper than $125, i suggest a DIY install, and save yourself some $$$.
Old Jan 7, 2003 | 02:03 PM
integRacer05
i tried the tapping it down way, and it got all the way down, but all my radio stations were very fuzzy so i pulled it back up, and thanks i'll try the other way
Old Jan 7, 2003 | 02:17 PM
90'RS's Avatar
90'RS
I just leave mine equel with the cabin area and I get good enough reception. Doesn't look the best but is better than all the up.
Old Jan 7, 2003 | 03:09 PM
Orange95GSR's Avatar
Orange95GSR
LOL
Mines been up for months. Atleast I know how to get it down now. Thanks
Old Jan 8, 2003 | 04:52 AM
integra_blurred's Avatar
integra_blurred
Objects in mirror are loo
dang, this must be common as hell on 95 'tegs, cause my antenna's stuck in the up too....think i'm gonnna try an s2k antenna swap, 'cept i've heard the reception sucks w/ this, ne one know ne thing about that?
Old Jan 8, 2003 | 09:44 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
lol, I had the same problem except it was stuck in the down position (no reception period). I punched the top of the mast a few times and it went up just fine.
Shingo
Old Jan 8, 2003 | 11:47 AM
integRacer05
ya, my friend told me about that, it seems like a pretty good idea and it looks good
i think u can get them for about $35 off the internet
Old Jan 8, 2003 | 05:29 PM
timmy8151's Avatar
timmy8151
First thing you have to do is figure whether the antenna motor is broken or just the mast. If it the motor, then you'll have to spend some money. However, if its just the mast, you can get one off ebay for about $25.
Most likely, the plastic cable of the mast broke. If this is the case, then all you need to do is remove the plastic lining inside your trunk. Unscrew the antenna motor , open it up and take out the old antenna. Put back the motor, then feed the new antenna cable through the top.
I was going to do a s2k atenna, but I hear reception is bad w/o the factory signal booster. I listen to a lot of AM, so the s2k would be no good to me.
Old Jan 8, 2003 | 05:41 PM
integRacer05
thanks a lot
here's a pic of of the s2k antenna
