hey but first you have to find where the spark is getting out before the plug. more then likely its gonna be on the black part right before the plug in the valve cover. the way i found mine is crank my car pull the plug hold it down in the spark plug hole and see if it sparks. if it does then you found your prob. it might just be a worn wire (the wire has mostly broke on the inside of the rubber) but i doubt it cause it simply doesnt move enough to break. but anyhow just thought i would let you know some more info about the prob and the quick fix
