Need help, engine problems...
Old Dec 24, 2002 | 11:48 AM
Bui1t2Spill's Avatar
Bui1t2Spill
is it possible that water water in my gas could be doing that? It has been raining alot today
Old Dec 24, 2002 | 11:58 AM
crash's Avatar
crash
oh it been raining,do you have a cold air intake?
Old Dec 24, 2002 | 12:03 PM
Bui1t2Spill
yeah i do
Old Dec 24, 2002 | 12:06 PM
crash's Avatar
crash
do you think that it might of sucked up water?
Old Dec 24, 2002 | 12:07 PM
Bui1t2Spill
hmm i guess it could be possible, should prolly put some gas treatment stuff in and see
Old Dec 24, 2002 | 12:36 PM
crash's Avatar
crash
don't need that do a search for hydrolock and check what the threads say,like draining your oil and stuff
Old Dec 24, 2002 | 01:05 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Get a compression/leakdown test done, ASAP.
Old Dec 24, 2002 | 10:50 PM
Bui1t2Spill
aight im gonna do a compression test tomorrow... see what that comes up with. Whats is the compression sposed to be for a 91 LS?
Old Dec 25, 2002 | 09:26 AM
red.da's Avatar
red.da
if it sounds like its 'missing' you could have a sparking problem, happened in my LS before, check your plugs/plug wires/dist cap/ rotor and make sure all your plugs are still sparking. sometimes just replacing all those things along with a new air filter and fuel filter can make a world of difference.
as for the compression test just look for consistent numbers accross all 4 cylinders.. anywhere from 160-180 would be good numbers as long as they dont vary much. ie - 160-160-160-160 would be alot better than 185-185-130-185.
good luck
Old Dec 25, 2002 | 06:23 PM
Bui1t2Spill
Thanks for the info man.. im pretty sure it isnt water... like when i keep it at like 4000 rpm it isnt missing... but when i put it in gear and try to go its like sputtering and missing pretty bad... But im gonna go check my plugs n stuff... so we'll see what that shows.
