Intake Manifold Options
Old Dec 19, 2002 | 06:08 AM
ShaolinLueb's Avatar
ShaolinLueb
skunk2 man. they seem to make decent applications for everyday and racing.
Old Dec 19, 2002 | 07:07 AM
jeems's Avatar
jeems
i be slow
well it is pretty much a stock LS engine so probably 7 or 8 psi. that would be about the max that i could run right? without messing something up.
Old Dec 19, 2002 | 07:13 AM
XSrcing's Avatar
XSrcing
the JG is made for high boost pressure, which are seen on all out drag cars. your 7-9psi LS will not gain anything over the Skunk2 except for a minimal amount of turbo lag. so go with the skunk2.
Old Dec 19, 2002 | 07:25 AM
qtiger's Avatar
qtiger
Originally posted by jeems
I guess you're right but tell me what the downside to the large size is then.
Intake air velocity goes down the crapper.
Old Dec 19, 2002 | 07:38 AM
LT's Avatar
LT
The deer had to die!
7-8psi...Skunk2 it is! :thumbup:
Old Dec 19, 2002 | 09:26 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
This is a dyno of a big output motor with a JG manifold:
Look at what RPM the plot starts at. 5000. The turbo fully spools after that RPM. The manifold helps peaky motors like that to breathe better. Unless you're going to be making similar numbers I would stick with the skunk2.
Old Dec 19, 2002 | 09:22 PM
thx247's Avatar
thx247
air speed goes down with too large an exhaust or too large an intake.
Old Dec 19, 2002 | 09:33 PM
trbo's Avatar
trbo
get revhard manifold
Old Dec 19, 2002 | 09:53 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Since when does RevHard make an intake manifold?
Old Dec 20, 2002 | 02:00 AM
DB7 2.0's Avatar
DB7 2.0
Banned
bigger is not always better...
you can just get your stock manifold ported n polished along with the throttle body and then have everything port matched to each other and the head...this might cost a bit more than an aftermarket int.manifold, but it'll flow just as well, if not better (being that the runner length and angle of entrance to the head is designed to work efficiently with the head), and itll definitely have increased velocity.....but then again, if youre going turbo, youre creating your own velocity..so then you can just throw out my suggestion and go with a short fat intake runners and turn up the boost. naturally aspirated ownz joo!!!! :fawk:
