Changing own head gasket?
Old Dec 14, 2002 | 08:11 PM
t3t4's Avatar
t3t4
Default Changing own head gasket?
Is it worth changing your own head gasket on a 94 GSR or is it a real pain in the ass, How much does it usually cost at a garage to get it done?
Old Dec 15, 2002 | 11:32 AM
ISP James's Avatar
ISP James
DAMIMRED
probably easier to sell me your motor
seriously though, its a bit of work but its a good excuse to play around in there, maybe do some head work.... not sure what the going rate is.
Old Dec 15, 2002 | 11:43 AM
XSrcing's Avatar
XSrcing
get yourself a helmes manual, and do it yourself. it should only take you a couple hours. but make sure you have a torque wrench that is in good calibration.
you will get charged about 2-3 hours labor plus parts at a shop. that would be around $250-$300.
Old Dec 15, 2002 | 12:01 PM
reno96teg's Avatar
i think you're making it sound easier than it actually is. 1st, there's a chance the head might need to be resurfaced. 2nd, you have to make sure that you unbolt and bolt everything in the right order and torque it down correctly otherwise you might warp the head. 3rd, you have to undo the timing belt and all to do this job.
i don't recommend that the average joe take on this job on their own.. especially if they have experience doing just simple things like oil changes and brakes..
Old Dec 15, 2002 | 12:39 PM
b00gers's Avatar
b00gers
doing the head gasket is major work, if you had to ask if itll be ok to do it yourself, its probably not.
Old Dec 15, 2002 | 02:42 PM
XSrcing's Avatar
XSrcing
true. we did it on my friends teg. it just seemed tedious, not hard, to us. but thinking about it, i would not do it unless you had a thorough understanding of you tegs engine.
Old Dec 15, 2002 | 08:08 PM
aut0tek's Avatar
aut0tek
I've done a couple headgaskets and I'm far from ASE certified. Lol.
Then again, I have done my 12:1 LS/VTEC swap by myself too.
Only thing that sucked was the Clutchmaster's stage 3.
Anyhow, I would say go for it go buy a manual and follow it and you will have no problems.
Harry
Old Dec 19, 2006 | 04:54 PM
roman05's Avatar
roman05
Hey.. My 95 Tegra Se Is Overheating, Maybe Its The Head Gasket..so I've Heard.. Is This A Diy Job... Or Should I Just Kiss It Goodbye...
