Short Ram or CAI?
Old Dec 20, 2002 | 09:39 AM
aux's Avatar
aux
More Black on Black Crime
kinda ot, but helpful =].
https://www.honda-acura.net/forums/s...threadid=40592
Old Dec 20, 2002 | 10:45 AM
97teg's Avatar
97teg
The thing I like about my icebox is that you can get to the filter from the stock location and its tested against hydrolock. I have just the filter and ice box not the short ram but even then it is still a bit more expensive.
Old Dec 21, 2002 | 04:06 AM
Louse76's Avatar
Louse76
Team Teg Project Car
Originally posted by 98SmeLS
Putting cold air into your engine makes more power because cold air is denser than warm air. That means more oxygen, more combustion, more power.
The CAI doesn't give more power because of colder air. Your engine bay is actually pretty cool with air moving around in there etc. If it was giving more power because of cooler air, then you would see a gain accross that whole dyno.
Rather going from SRI to CAI simply works like changing your intake manifold, you're swapping where you want your power. The CAI is going to give you the extra power at the AEM hump as you can see in the dyno. The SRI is going to give you extra power way up top (higher than most of our tegs will ever rev), up past 8.5k. At that range, the CAI's power just drops off. So essentially it has to do with the velocity of the air coming into the engine and the effect of the length of the tubing... the temperature differences aren't enough to make any sort of real world difference.
Old Dec 21, 2002 | 11:26 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Your "moving power around" theory doesn't stick here. The "AEM hump" comes from a resonance supercharging effect because of the length of the pipe. But as the dyno that's been posted all over the place shows, the CAI doesn't loose any power to the filter on a stick.
Yes, when you increase breathing capacity with piping length or manifold size there is generally a shift in the powerband, but horsepower is not like matter in that it can be moved and not created and destroyed.
Old Dec 22, 2002 | 06:23 PM
98SmeLS's Avatar
98SmeLS
You're gonna have to clear something out for me, where exactly do you not see a power gain? What chart are you referring to? (car, mods)
High school thermodynamics man, PV=nRT. Why do you think an intercooled turbos make more power than non-intercooled. Temperature is inveresely proportional to density. Why do u think the call it a "COLD" air intake.
The SRI will make power way up top, if the intake piping is very large. Smaller pipes give higher velocities, so the powerband is going to be different for different size pipes. Large pipes will work well up high, small will work well down low. Just like exhaust piping.
CAI high longer pipes and more bends than SRI. That, and the fact that it has to deal with water, is the only disadvantage vs SRI.
