Throw out bearing or .............
Ok i have a problem, i have a noise in the tranny its like a grinding kinda almost sounds like a tire in a fender wheel rubbing "its hard to explain" but when i push in the clutch the noise stops no matter what gear im in. What would i need to fix or get, there was a clutch (OEM)installed about a year ago and i dont think the bearings were changed, and the car has 200K on it. Do you guys think it sounds like a throw out or pilot bearing or do i need a new tranny?
Yeah, I had the same problem in my civic. It was the
main shaft bearing. Makes a noise while driving,
disengage clutch and it goes away.
You can replace the inexpensive bearing if you know
what your doing inside a transmission, I just went
w/ a used tranny I found cause it worked out being
cheaper than the labour.
My car makes a squeking sound when i push in the clutch sometimes. My mechanic thought that it was the throw out bearing.
He said i could leave it alone because it is just an annoying sound, it will not hurt the car. It costs quite a bit to replace.
