No Heat?!!?
Old Nov 29, 2002 | 10:40 AM
yellowbastard's Avatar
yellowbastard
Bootyologist (__i__)
Default No Heat?!!?
95 Teg LS..
Why is there no heat? What should I look for..? The fuses appear to be good...the a/c works fine but when you put it on heat..it just blows cold air..
any help is appreciated.
Old Nov 29, 2002 | 10:54 AM
ur31337's Avatar
ur31337
Colby
Check your coolant level. In my experience, without antifreeze, you won't get heat.
Maybe your heater core died.
Old Nov 29, 2002 | 10:58 AM
yellowbastard
where is the heater core? and how much does that usually run for a new one...? and how hard to install? keep in mind i've done 3 hybrid swaps in civics/crxs...but dunno anything about heating probs
Old Nov 29, 2002 | 11:00 AM
ur31337's Avatar
ur31337
Colby
I've got no idea at all. I just know that my friend's Bronco had a bad heater core and he had no heat.
Old Nov 29, 2002 | 11:45 AM
g2tegls's Avatar
g2tegls
MR, ftw
I dunno how much it costs but it's buried in behind the climate control so basically it would take a while to get to it.
Old Nov 29, 2002 | 01:25 PM
reno96teg's Avatar
what does your engine temp read at? if it stays cold, your thermostat is probably stuck open. otherwise, as already stated, it could be low coolant or dead heater core..
Old Nov 29, 2002 | 04:05 PM
alnen's Avatar
alnen
My guess is the heater core. I'm 99% sure that's the problem. They aren't very expensive to replace, doing it yourself is cheaper but a little pain in the butt.
Old Nov 29, 2002 | 04:21 PM
fanatic's Avatar
fanatic
Also, there's a hot/cold air adjuster underneath the passenger side of the dashboard, might want to check things out underneath there.
Old Nov 29, 2002 | 09:41 PM
maxrpm's Avatar
maxrpm
you should check the hose going into the firewall if its hot. IF its not than either your thermostat is stuck closed. If they are hot than it might be your heater core. The heater core on the 94 teg and up is under the glove compartment.
Old Nov 30, 2002 | 05:22 AM
yellowbastard
yea sorry guys..i forgot to post once i fixed it yesterday.the temp guage was reading properly..cold when cold..warm when warm...i browsed the tech forum on Honda-Tech and someone also said to check this..some how this rod adjuster piece was disconnected completely..i recently got the car and it came this way......EASY FIX...thanks guys
