My GSR NA Rebuild
Old Jul 22, 2009 | 08:48 AM
  #71
jesusublime99's Avatar
jesusublime99
Originally Posted by JaYdM.JnKy
It suited your power demands so far, so I guess It's good enough. Just know for a high power band and peak hp an ITR manifold (oem) would suit the setup best.
I'm not looking for peak hp and don't forget that an OEM ITR intake manifold does not fit a P72 head. I built this engine package to have the most power from mid-to-high RPM; not just at redline.
What is a higher peak HP going to get me? Nothing. You spend a fraction of a second at peak HP. However, every time I shift, I'm in the 5k-8k rpm range for 3-6 seconds. Where do you think the most torque and horsepower is needed?
Old Jul 22, 2009 | 12:47 PM
  #72
Spec R's Avatar
Spec R
but thats not "the essence of a true NA engine".
DB Squad
Integra Forum Moderator
Old Jul 24, 2009 | 10:09 AM
  #73
jesusublime99
"True NA essence" is too expensive!:faint:
Old Jul 24, 2009 | 11:45 AM
  #74
JaYdM.JnKy's Avatar
JaYdM.JnKy
R.E.S.P.E.C.T
I know the ITR manifold doesn't fit...w/out modification, but you claimed "oem" so I gave you a better oem part reference.
If the engine was built for mid to high then that is the wrong manifold. If it was built for best mid range response then that is the correct manifold, but since the true essence of an NA engine was covered and you've replied to it, then your happy, I'm happy.
:thumbup:
Old Jul 27, 2009 | 08:00 PM
  #75
jesusublime99
:thumbup:
Thanks for the input, I'm sure we will help future readers with their decisions.
:cheers:
Old Jul 29, 2009 | 12:28 AM
  #76
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Great numbers for sure. I'll be doing this but with a 2.0L block and a slightly bigger crank. Maybe a little more compression, but not sure yet.
Old Jul 29, 2009 | 06:43 AM
  #77
GSRRacer95's Avatar
GSRRacer95
Fight On!
So what are your plans from here?
Old Jul 29, 2009 | 04:26 PM
  #78
jesusublime99
Off the top of my head, a fuel pressure regulator sometime soon and a 2.5" Hytech exhaust in the future.
There some suspension maintenance that has to be done before I try to add any more power. I need to replace
most of the bushings and install new caliper rebuild kits all the way around. As well a camber kit all the way around
and some new rear control arms.
Old Jul 30, 2009 | 04:51 AM
  #79
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
The Energy Suspension master bushing kit is great. I installed them on my car and it made a world of difference.
Old Jul 30, 2009 | 06:46 AM
  #80
GSRRacer95's Avatar
GSRRacer95
Fight On!
If your are looking fro OEM stuff, I just hooked Chef up with some stuff. I would be willing to do the same for you. Just PM me if you are interested.
