Question about shift linkage
Old Oct 30, 2002 | 07:16 AM
KyleMX6's Avatar
KyleMX6
Default Question about shift linkage
I am working on a 1990 acura integra 5 sp. I cant see how to get the shift linkage off of the transmission. It looks like there should be a bolt through it but it isnt a bolt. It almost looks like pins. Whats the deal? Thanks
Old Oct 30, 2002 | 09:41 AM
lttletimmy's Avatar
lttletimmy
If i remember correctly, there's a rubber boot over the part closest to the tranny. You have to slide that rubber boot back and that will reveal the pin you have to knock out. After you get the pin out it should separate just fine.
Old Oct 30, 2002 | 09:58 AM
tilt's Avatar
tilt
yep that's right.
http://www.c-speedracing.com/howto/b18cswap/swap.html
The Internet is your friend.
Old Nov 1, 2002 | 11:34 AM
KyleMX6's Avatar
KyleMX6
Default Yes the internet is good
too bad i was done with the clutch by 700 though. i just unbolted it at the shifter and took the whole bar out...oh well. Thanks for the help though, I will know next time
