car question V.battery?
Old Apr 4, 2008 | 06:15 AM
Tark's Avatar
Tark
yeah just car a reputable garage and they said they'll test the system for me.
i still dont think its the alt i mean no light, no hesitating never dies on me while running. you might be right though jesse guess i'll know later today.
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Sorry...didn't quote. Was reading this when i hit reply :
Originally Posted by Tark
but if alternator is gone then the car wouldnt run for veryy long right?
Old Apr 4, 2008 | 06:34 AM
im almost positive you will find its the battery or something draining the battery.
Old Apr 4, 2008 | 06:37 AM
Tark's Avatar
Tark
hope so cause i aint got no cash for alt right now. although finding was is draining the batt could be a bitch too...
Old Apr 4, 2008 | 06:44 AM
thats why i said take it to a parts store h:
free testing and replacement ... a shop usually charges for all that. although many will waive the testing fee if you buy the battery from them
Old Apr 4, 2008 | 06:54 AM
Tark's Avatar
Tark
yup that where i am going. i didnt know many part stores here but last time the cab driver told me about one. i figured i could trust this cab driver
Old Apr 4, 2008 | 09:17 AM
canada's Avatar
canada
514.315.407.405
Ah Canada... where cabbies come to give you a boost instead of a ride. And are ok with that.
Old Apr 4, 2008 | 06:54 PM
drive4show's Avatar
drive4show
In which case, you can just keep calling a cab for a boost! :canada: :thumbup: :rockon:
A third solution (besides 1. take it to get checked, and 2. just buy a new battery) is to measure the DC voltage yourself, if you have a voltmeter handy.
More info here, for example. Measure voltage after the battery has been sitting around overnight or so; 12.4V or below points to battery not holding a charge.
Also measure voltage while car is running; it should read about 13.5V, which would indicate the alternator is putting out enough juice, which recharges the battery while you are driving around.
Good luck!
Old Apr 4, 2008 | 08:12 PM
Line7's Avatar
Line7
Platinum Member
I think you batt. terminals are just loose. From personal experience, they have to be on there pretty tight. Clean them up well, put anti-oxidation lube on them and make sure they're really tight, you should not be able to wiggle the wires at the post.
Old Apr 11, 2008 | 08:09 AM
Venom62's Avatar
Venom62
i had the same problem. turned out the brushes in the alt were worn out. it only tripped the battery light at a slow idle.. simple way to check the alt is to pull the negative terminal off the battery and see if it runs better or worse, or not at all.
