Passenger wheel feels loose
Old Feb 9, 2008 | 02:28 PM
SkaterMaggot's Avatar
SkaterMaggot
Default Passenger wheel feels loose
When i jack my car up the passenger wheel feels loose the rotor to but I don't know what it could be axle is as tight as it can be any help would be appreciated
Old Feb 10, 2008 | 08:55 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
If the whole wheel assembly moves when you put pressure on it while tilting it back and forth or up or down you may have a worn upper or lower ball joint. Also check for worn control arm bushings or worn tie rod ends.
Old Feb 11, 2008 | 12:33 PM
[H]ereitcomes's Avatar
[H]ereitcomes
Honda Rookie
if you grab the wheel, and if it has play to the left or right, it signifies a tie rod end. If you have up, and down movement, or forward to back, you my freind are in need of ball joints. You will be able to see each piece move if it needs to be replaced.
