Help with installation of CAI on '93 Integra GSR
Is there a step by step guide WITH pictures? I can't seem to follow the instructions that came with the parts.
I don't know which one is the breather hose, or the water bypass hose, or the intake manifold, or the water outlet, or the resonator. -_-;;
Re: Help with installation of CAI on '93 Integra GSR
the intake manifold is the big hole...2-2.5" in diameter. its the part that is actually connected to the engine.
so the breather tube is the blue tube that goes from the intake..then under the strut bar...then to the valve cover.
the intake manifold is 3-4 inches to the right of the breather tube on the intake.
thats the best i can do with pics. this is not a gsr btw.
Banned
da heezy... k here it is...
the intake manifold is that silver metal thingy that looks like 4 pipes melted into each other. its stuck onto the engine towards the "back" (when looking it at directly from the front of the car). now, to the very left end of the intake manifold, you'll see another small thing that has a bunch of hoses and cables stuck to it. this is your throttle body. attached to this throttle body is your intake pipe. since youre putting on a new aftermarket one, you gotta take off the original factory pipe (its like a black rubber hose with ridges). basically, you see a clamp/ring holding the pipe onto the beforementioned throttle body. you unscrew this loose, and the factory intake pipe slips off like a prom dress.
you grab the new aftermarket intake pipe... you can do two things first...put the silicone hose connector thingamajig on the intake pipe first and then attach it to the throttle body, OR you can put the silicone hose connector thingajiggy on the throttle body first then attach the intake pipe to it... DONT forget the two O-ring clamps/screws. you need to put 2 of these on the connector thingy before you put the intake and throttle body together.
and youre done!
hope this makes sense to you. i tried describing things as least technical possible.
and youre done!
lol, yes that helped a bit. But don't I need to take out the "stock air box" thing like the instruction said? Where is that?
on one end it connects to the engine right? well that end is the throttle body and intake manifold.
on the other end its connected to a small black box. thats the "airbox" and houses the filter.
there should be 3-4 bolts holding the box in. take those off to remove the box.
NAM #0001
Remove the whole black box, because that's the area where the CAI pipe will go through. Then connect the filter to the end of the piping and connect the piping to the Intake Manifold with the little metal brackets. Also don't forget to cut the pipe somewhere and put your bypass valve in.
Banned
Originally posted by WiLL
ok ghetto photoshop but:
A- intake manifold
B-Throttle body, its hidden, but would be there
C- stock intake
D- air box.
hope that helped a little.
A- intake manifold
C- stock intake
D- air box.
