My brother blew his valves, HELP!!!!!!
Old Oct 17, 2002 | 11:37 AM
2002Si's Avatar
2002Si
yeah he bent 2 I think because 8 springs are still compressed, 4 on either side
Old Oct 18, 2002 | 05:37 AM
qtiger's Avatar
qtiger
Originally posted by AcuraFiend
what exactly does it mean to "float a valve" what are some other similar conditions that can occur?
It is when you overrev your engine or use cams that are too aggressive for your springs. Your springs aren't strong enough to pull the valve back all the way in time. The valve 'floats,' and you smack it with your piston.
Voila, bent valve.
Old Oct 18, 2002 | 09:22 AM
titaniumGSR's Avatar
titaniumGSR
what if u just barely go over redline?.. like instead of 8100.. i go to like 8200 or whatever.. when i did that in 2nd gear.. my engine seemed to like die all of a sudden till i hit 3rd
Old Oct 18, 2002 | 03:34 PM
LT's Avatar
LT
The deer had to die!
that's called a rev limiter...be happy it's there.
Old Oct 19, 2002 | 07:12 PM
integra-boy's Avatar
integra-boy
yes, thats a safety feature designed so that you don't kill your engine. the power automatically shuts off to the engine once you exceed the redline max, kind of like pressing the clutch in.
