civic engine in a teg??
if you are going to decide to go with the B16...then you have no choice but to build it up if you want to be quick. yes the B16 was offered as the engine in the DA model in Japan, but it was not impressive at all. ive seen DA integras with B16 swaps, and theyre ummm...ok i guess? its the built ones that actually get moving
Originally posted by hks240sx
i say get teh b16! ! that thing is a monster and it has VteC, now its a monster on drugs!
Isn't that an oxymoron? I'd get a 2liter CRV block personally, and put your LS head on it.
First off, if your LS head is still good it will bolt right up, so all you have to buy is the shortblock. 2nd, it's been rumored to flow better than the CRV, but I haven't seen any flowbench numbers.
i have two options rite now..jus the engine w/o tranny
if i get the b16a wit je pistons, eagle rods, a strong head gasket w/labor is 2700
the same with an ls engine, which is wat i have and stay with the same ls turbo set up is 50 dollars cheaper..
so wat im saying is that with this..they're basically the same price..but which way should i go?
Guest
Posts: n/a
Originally posted by g2tegls
The b16a with the LS tranny will be slow. A turbo LS will be faster than any n/a B16a. I'd go LS turbo if it's cheaper.
They'll never know what hit 'em.
