Tail Light's Acting Funky
Old Oct 24, 2007 | 02:17 PM
Zooty's Avatar
Zooty
Jimmy John's Driver
Default Tail Light's Acting Funky
I have a 96' LS, and the left reverse light doesn't come on at all, but more importantly my left brake light works fine normally, but when the headlights are on and I apply the brake, my whole left tail light goes out, but the right works perfectly fine..
There was a lot of water which we cleaned and I dont think it's the bulbs..
Old Oct 24, 2007 | 02:50 PM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Too test if it's the bulbs are faulty put the ones from the left tail light into the right one since that works. If the bulbs work then they're fine. Also check for any fuses blown due to there being water in the tails. Do you have someone looking at your tail lights while you're in the car?
Old Oct 24, 2007 | 03:04 PM
Zooty's Avatar
Zooty
Jimmy John's Driver
Yeah my dad's outside looking, he's a mechanic, and he figures it's probably a short, and might wire the brake lights from the right lens to the left and the same with the reverse..
Just wondering if this was a common/easily fixable problem :P
Old Oct 24, 2007 | 03:07 PM
v6_accord_jerz
Stupid Power Ball
Not common atleast to me. I've owned (still currently do) 3 integras over the past 6 years and never heard of this problem. Your dad shouldn't have to wire everything over. Just check all fuses and connections. Did this just happen or did you just buy the car and figured this problem out?
Old Oct 24, 2007 | 03:26 PM
Zooty's Avatar
Zooty
Jimmy John's Driver
Well we just bought the car, and we knew it did this when i bought it (a 96 LS for 2k was hard to find considering thats how much 90' LS's go for around here, and there's not many!) but this is the ONLY problem (aside a few dings I'll have no problem getting out)
We checked the fuses and all the bulbs, the tail light was full of water so we drained it, and dried it, and it still acts the same.. so we think its the wiring and we don't wanna take the whole car apart unless we have to (which we might to get the rear speakers in anyway >_<)
Old Oct 24, 2007 | 07:15 PM
91integrafl's Avatar
91integrafl
Default i had that problem with my step dads ford contour that i was using for a while.
The bolp for blinker break and tailight was this same and brake light worked but the blinker and tailight didnt and i changed bolbs and it was fine.
Old Oct 29, 2007 | 04:26 PM
slintegra's Avatar
slintegra
theres two sets of fuses... did u check the ones under the hood too
Old Nov 1, 2007 | 10:23 AM
Zooty's Avatar
Zooty
Jimmy John's Driver
oh...no i didn't.. I'm gonna go run outside and check right now
i still think its from water leaking into the housing and rusting/shorting the bulbs.. im gonna try new tails or the wiring idea but first BE RIGHT BACK
Old Nov 1, 2007 | 11:32 AM
cruzalekz's Avatar
cruzalekz
You need a wiring diaghram and a short finder(tool for finding shorts). And this short is hapenning between the brake switch wire all the way to the taillightwires that is not working once the brake is depressed. You could also trace the wires and look for ones that are abviously pierced by a screw or even stripped wires contacting the frame and shorting b+ to ground.
