quick camber kit question.
Old Oct 15, 2002 | 07:36 PM
Spec R's Avatar
Spec R
heres the dilly yo! jk will
if u have the same kit as me....the max setting is at -1.25 degrees
DB Squad
Integra Forum Moderator
Old Oct 16, 2002 | 06:35 AM
b00gers's Avatar
b00gers
i have the next kit....from -1.25-3 i think
what the max negative camber i can go? for daily driving.
Old Oct 16, 2002 | 12:04 PM
LocaL raCer's Avatar
LocaL raCer
R.I.P. Kato-san
:whOre: h:
Old Oct 16, 2002 | 01:29 PM
Spec R's Avatar
Spec R
yeah u have the same kit...i loosened the bolts in the fenderwell...pushed the a-arm back in as far as it'll go, so i wont mess up the alignment...so its set a +1.25 degrees compared to whatever the stock setting would be at, given my 2.5" lowered ride height. i run my car quite low, and since i'm on the stock mesh rims with 195/50/15 kumho 711's its even lower. my Apex-i resonator is about 3 inches above the ground .
when i had the kit installed at first, my guy set it at 0, causing better tire wear, but nastier understeer...this is why i pushed it back in. now, the front has a little more negative camber than the rear.
DB Squad
Old Oct 2, 2003 | 01:54 AM
city's Avatar
city
Default Do Ingalls Rubber Camber Kits Squeak In Hot Weather?
I've been doing some research about Ingalls camber kits with rubber bushings squeaking. And I have found some feed back that they do squeak if there is too much preload, and just found this thread where Quoted:
originally posted by WiLL
*does your kit squeak at all? more during hot weather? mine does and i have the rubber bushings kit.*
And wondered if anybody else experienced squeaking noises during hot weather?
I'm not sure what kinda of ingalls camber kits i have (rubber or Poly), all I know is that they do squeak when the weather is hot.
At night time when the weather is cold I don't hear anything.
So I guess I have the rubber bushing cambers, I think? Does anybody know how to tell the difference visaually between the Ingalls 35720 and 35730 camber kits?
Any feedback is appreciated thanks!
Old Oct 2, 2003 | 10:10 AM
Spec R's Avatar
Spec R
Hey City, I've tried countless times to grease and lube my kit, and it still squeaks annoyingly. In fact I just emailed Ingalls a detailed explanation of my problem. I'll make a new thread when i get a response from them.
DB Squad
Old Oct 2, 2003 | 12:42 PM
city's Avatar
city
Default I Think It's The Weather?
Cause when I drive my car during cold weather it never squeaks, but like on a hot day when my car struts going on uneven roads it squeaks. Anybody else having same or simular experiences?
Old Oct 2, 2003 | 10:02 PM
city's Avatar
city
I think rubber bushings get soft when the weather is hot so that is why it squeaks well more like a squishing sound not so high pitch. But then again i never heard a car with poly bushings squeaking before, but I've has skateboards with poly bushings before and they do squeak alot.
