Camshaft seal-
Old Jul 13, 2007 | 05:12 AM
m735is's Avatar
m735is
Default Camshaft seal-
90 Teg:
I wasn't sure how to replace the cam seal, so I pulled the old brittle one out (very hard since obviously this isn't the way to do it). Do I have to take off the valve cover and rocker assembly to replace this? My replacement is a stock one. I just did the valve gasket and really didn't want to replace it again if I don't have to.
Or can I just cut the inner lip off and hold the seal in using a strap or cover plate held on with the two tapped holes next to it? At least until I have to remove the valve cover again for an adjustment.
Old Jul 13, 2007 | 09:15 AM
mberndt's Avatar
mberndt
Originally Posted by m735is
90 Teg:
What???
Yes, you must take off the valve cover in order to replace the cam seal.
It's only 8 bolts...
You don't need to replace the valve cover gasket everytime you take it off.
Hell, I haven't replaced mine in years and I just rebuilt my motor.
Of course, I clean it and check for cracks, etc before I re-use it.
Do it the right way and don't try and hold in the seal with a strap...
This would be more work than simply following the directions anyway...
Old Jul 13, 2007 | 10:37 AM
m735is's Avatar
m735is
Do I have to remove the rocker assembly to get the seal in?
Old Jul 14, 2007 | 06:59 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have to remove the cam cap.
