Good alternative
Old Jul 9, 2007 | 03:22 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by Difussion3
Is the es tuning muffler really loud? My friend has it on his civic si but hes straight piped so its pretty loud. How loud will it be on my car with a cat and resonator?
Well, a longer perf-core resonator will help cure the buzzy higher-pitched sounds. But with 2.5" tubing, expect a fair bit of low-pitched drone at cruising speeds. I speak from experience because I used the same diameter mandrel-bent tubing with a similar muffler and resonator on my last car, a 91 GTI.
IMO, you're still better off with a system like the Apexi WSII. It has plenty of flow capacity for minor bolt-ons and it does a much better job of managing sound at highway speeds.
Old Jul 9, 2007 | 03:27 PM
Difussion3's Avatar
Difussion3
Touge
Yea, I'll probably go with the WSII, will it work well with 2.5" mandrel-bent piping? Thats what I was thinking of getting.
Old Jul 9, 2007 | 04:21 PM
TheOtherDave™
Apathy Kills
No.
The WSII is a fully welded cat-back exhaust using 60 mm mandrel-bent mild steel tubing. While you could replace the 60 mm tubing with 2.5 inch tubing, it's a pointless waste of money given your goals.
60 mm ÷ 25.4mm / inch = 2.36 inch
The reduction in diameter for the WSII is trivial... we're talking about an 1/8th of an inch here.
Old Jul 10, 2007 | 03:04 PM
Difussion3's Avatar
Difussion3
Touge
The only reason why I said to go for 2.5" is because I just got the muffler. The catback costs like a lil over 500 with taxes n shipping n stuff... I can get 2.5" mandrel-bent custom piping for a lil less thatn $100 plus the muffler was $205, so it comes out to like give or take $300.
Old Jul 10, 2007 | 03:50 PM
TheOtherDave™
Apathy Kills
Go for it if you want, but be aware that it may drone and buzz more than you want it to.
In my experience with a 2.5 in exhaust on an N/A motor... the 2.5 in tubing produced a fairly loud droning D-flat at about 75 mph on the freeway. By comparison, the WSII is much more tolerable IMO.
It's your choice.
Old Jul 11, 2007 | 02:51 PM
Difussion3's Avatar
Difussion3
Touge
Well I got my full exhaust installed today... Itr 4-1 header, hiflow cat, 2.5" piping, and apexi ws2 universal muffler. At first no resonator was installed, so when i tried it out, it was wayyyyy too loud for me... then I went back and he installed a resonator and it quieted down a lot. The only time it gets really loud is when vtec kicks in. I don't mind how loud it is, but I was thinking it would be a lot quieter.
Old Jul 11, 2007 | 08:01 PM
lazieb29's Avatar
lazieb29
saweet neeegrro!! ima call u now
