A/C out
Old May 16, 2007 | 03:06 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Default A/C out
Ok well i went down to a shop to have them put freon in my car today and they told me someone cut into one of the lines and it would cost $450 all together. So now i'm just going to take it out. Don't really know what i'm doing but i'm going to try. Any tips would help alot. I'm going to start the pull tomorrow afternoon.
Old May 16, 2007 | 03:37 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Just pull out anything A/C related. It is probably the most fun you will have working on your car. Start at the firewall and remove everything including the dryer, belt, condenser, all related relays, compressor, lines, and drivers side fan. Total weight savings will be ~28 lbs. I stopped at the firewall because if the evaporator is removed without a block off plate, the ducts will not be functional and the blower and heat won't work properly anymore.
Here is my thread about this same subject.
Old May 16, 2007 | 04:01 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Well the only problem i will have is i dont know everything that A/C related.
Old May 16, 2007 | 04:09 PM
Provocateur
On permanent hiatus
Start at the A/C compressor. Remove the belt (I just cut it off), remove the compressor and then follow the lines out to the dryer (under the chassis next to the windshield washer reservoir) and condensor (radiator looking thing in front of the actual radiator). Then just follow the lines to the firewall. The drivers side fan can also be removed unless you want to wire it into the radiator fan for extra cooling.
Old May 16, 2007 | 04:18 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Ok thanks that helped alot. I'm going to start tomorrow afternoon. I'll post on how it went.
Old May 16, 2007 | 05:18 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Ok so i thought i would take the front bumper off tonight and start work tomorrow. I got all the screws on the top along the front off and the 2 blots on both sides. The fender well plastic was never connected to the front bumper. What else is holding it on?
Old May 16, 2007 | 07:10 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Never mind i got the front bumper off and am half way done pulling it all out. I will have pics tomorrow.
Old May 17, 2007 | 03:26 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Well i didn't take any pics but i have it out. Thanks for the help.
