Still need help with 01 gsr
Old Apr 19, 2007 | 10:04 AM
dubcac's Avatar
dubcac
I
Originally Posted by lazieb29
well if its an automatic the neutral safety switch is probalby bad
If it were somehow a magical automatic GSR, it wouldn't crank at all with a bad neutral safety switch...just like the clutch switch in a manual.
As for this problem:
Does the car drive oddly at all, feel sluggish, hiccup at all?
How do the plugs look? Fouled? Clean?
Could be fuel pump, main relay, fuel filter, starter on its way out...a lot of things...just gotta start narrowing it down.
Old Apr 22, 2007 | 10:33 PM
Ian01gsr's Avatar
Ian01gsr
yea i replaced the main relay too but like today after work i went to try and start it and it wouldnt so i just put the key ON and i could hear the pump go on and everything then it started, but the weird thing is that it always eventually starts
Old Apr 23, 2007 | 09:25 AM
lazieb29's Avatar
lazieb29
have you had the starter tested?? it could also be that its not engaging properly with the flywheel
Old Apr 23, 2007 | 09:33 AM
Ian01gsr's Avatar
Ian01gsr
yea everything tested out good when it was at acura last week only because it started everytime for them so unless it doesn't start on them then they can pin point the problem
Old Apr 23, 2007 | 12:46 PM
dubcac's Avatar
dubcac
I
Starter
Old Apr 23, 2007 | 12:58 PM
Ian01gsr's Avatar
Ian01gsr
why do u think its the starter?
Old Apr 23, 2007 | 04:39 PM
lazieb29's Avatar
lazieb29
i'd say starter or ignition coil.. you can have them tested both at autozone
Old Apr 23, 2007 | 05:20 PM
dubcac's Avatar
dubcac
I
Because it happens intermittently, and you replaced the entire ignition system. Fuel pump turns on.
Old Apr 23, 2007 | 10:52 PM
Ian01gsr's Avatar
Ian01gsr
i already had the ignition coil replaced but if its the starter would the engine still crank?
Old Apr 24, 2007 | 04:35 PM
lazieb29's Avatar
lazieb29
well if it happens off and on then it can be your starter is going out.
