Best camshafts
Old Apr 8, 2007 | 12:27 AM
KrazyAboutHondas's Avatar
KrazyAboutHondas
all motor or nothing
Default Best camshafts
I have a poorman's type r motor setup and I was wondering what would be the best cams for my setup. Here it is:
B18c1 block(fully balanced,stock rods,arp bolts)
CTR pistons(stock bore)
block gaurd
Jdm B16a head
1mm oversived valves(radius valve job ,type r springs)
Jdm b16a cams for now
YS1 non lsd tranny
4-2-1 header
RS*R Exmag exhaust
It runs pretty strong with the stock cams, but I feel I can use some more power,was thinking about getting stock CTR cams, but not to sure. Any suggestions.
Old Apr 8, 2007 | 05:19 AM
Zedron's Avatar
Zedron
Turbo B20
Get the newer version Type R Cams as they are the same as the CTRs and you can more than likely find them cheaper because they are not "CTR"
Old Apr 8, 2007 | 06:07 AM
mr22na's Avatar
mr22na
Miss It.
block gaurd
Jdm B16a head
YS1 non lsd tranny
4-2-1 header
RS*R Exmag exhaust
is this setup in your DA =)
lucky bastard if it is...
Old Apr 8, 2007 | 08:25 AM
KrazyAboutHondas
yeah it's in my DA and I wouldn't call it luck, but thanx
Old Apr 8, 2007 | 08:33 AM
KrazyAboutHondas
I would prefer the 00-01 ITR or 98 spec CTR cams, but are these good enough for my setup.
P.S.
it's a daily driver
Old Apr 8, 2007 | 09:47 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
What are you using for engine management? Since the compression is so high, I would try to take advantage of that and run a more aggressive cam than CTRs.
Anything is going to be an upgrade, though. B16 cams are pathetic.
Old Apr 8, 2007 | 11:32 AM
Snoopy's Avatar
Snoopy
been there done that
with those pistons and their huge dome and the oversized valves i really wouldnt go bigger than ctr's or most company's "stage 1" unless you absolutely know your piston to valve and valve to valve clearances.
Old Apr 9, 2007 | 09:08 AM
KrazyAboutHondas
I wasn't planning on going any bigger than stage 1's, due to the size of my valves. I just wanted some different suggestions.
