Clutch & Header??
Old Apr 2, 2007 | 09:28 PM
gingas's Avatar
gingas
Default Clutch & Header??
How's everyone doing 2day. These are my ??'s I plan on lowering car no more than 1.3". I wanted to get some headers but was thinking either a USDM Type R ( is it 4-1 or 4-2 ) or DC . I hear alot of people stating 4-1 sits lower. Why do they sit lower than a 4-2-1? Either way would I need anything xtra or straight bolt on. I only have a sri. Wanted your opinion
Also, what clutch setup would you recommend for a daily driver & occasional track. Staying NA. Just want something slightly better than stock & of course rush hour stop/go traffic.
Thanks,
Old Apr 3, 2007 | 03:45 AM
Jan Niemi's Avatar
Jan Niemi
either header will work fine, 4-2-1 will probably help in the midrange whereas a 4-1 will help more on the top end. Either style should give you a little improvement over stock. Ground clearance is always an issue especially on lowered vehicles, not much you can do there except don't drive over speed bumps and steep driveways.
A 4-1 will usually hang a little lower because all 4 pipes go under the oil pan.
Clutch choice really comes down to the type of driving you do. Exedy, ACT and Clutchmaster all make very nice replacement clutches.
Old Apr 3, 2007 | 07:39 AM
Spec R's Avatar
Spec R
I had no problems with my ACT HDSS and ACT Streetlite flywheel.
Honestly, I think the money you're spending on you header this early in your car mod history could better be spent on a rear sway bar. look into a beaks kit.
http://www.beaksproducts.com/DC_Quick_Swap.htm
DB Squad
Integra Forum Moderator
