New Tires
Old Mar 24, 2007 | 10:22 AM
  #41
nsxtasy's Avatar
nsxtasy
I've had Kumho Ecsta's before and they were ok but if the SPT are better then i'll take your word for it. I'll pick up a set of these for my summer set up.
As I mentioned earlier, Kumho makes a lot of tires with the Ecsta name, everything from Ecsta V710 track tires to Ecsta STX truck tires. One of their best-selling Ecsta tires was the Kumho Ecsta Supra 712, and I suspect this is the one you're referring to. It was an okay "budget performance tire" in the late 1990s and earlier part of this decade, but suffered by comparison when the Yokohama ES100 was introduced in 2001-2002. (The Tire Rack did a comparison of the two, and the ES100 beat the 712 in all 23 of the 23 characteristics tested.) Its lack of performance against the competition is the reason Kumho then set to work developing its successor, which is the SPT and is much better than the 712 in every possible way.
While on the tire topic. I currently have 215/40R16 tires on my American Racing type sr (series 86) wheels 16".
Now before you mentioned for the stock 15" wheel, to get the 205/50-15 assuming that's the max? What i'm looking to get is a lil wider and low profile sorta like what I have now and 40 is pretty low. Getting 225/45R16 or even what I have now 215/40R16 should do me good with the Kumho Ecsta SPT right?
The basic objective in choosing a size for street tires is to select a size that has the same outer diameter as the stock tires. This maintains the accuracy of the speedometer and odometer and the general appearance of the stock tires, and avoids downsides such as rubbing on the wheel wells or fenders. 215/40-16 is too small for a GS-R (2.9 percent smaller outer diameter than stock) and 225/45-16 is too big (2.3 percent larger than stock, which will rub). On 16" wheels on a GS-R, you need either 205/45-16 (0.8 percent smaller than stock) or 215/45-16 (0.7 percent larger, which will not rub). Most tires come in one size or the other, not both; the SPT comes in 205/45-16. If you're looking for what the SPT has to offer - very good performance with very good treadlife at a very good price - then get the SPT in 205/45-16.
Old Mar 24, 2007 | 03:12 PM
  #42
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Nice!!! :thumbup:
Thanks for answering my questions.
I know exactly what I'm gonna get on tuesday. Kumho SPT 205/45-16 instead of the 215 cause i'd want it to last longer atleast for a few summers since i have steelies with winter tires and will be putting those on around October. Plus my 712's weren't too bad at the time (4 yrs ago), it'll be good to come back to Kumho.
Old Mar 25, 2007 | 06:39 AM
  #43
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Nice!!! :thumbup:
Now why would you want to do that when you could have the Mashimoto zx tire for about 5 bucks more per tire?
J/K
