do shocks typically get stiffer when its cold?
Old Mar 15, 2007 | 12:26 PM
bnuk's Avatar
bnuk
Default do shocks typically get stiffer when its cold?
I've noticed that my konis get noticable stiffer when it gets cold. like last month when it was below zero for a few weeks it was getting almost unbearable. I didn't connect it to the cold until it got real warm all of the sudden I realized the ride was a lot smother. Oil viscosity is usually very temperature dependant so is this pretty normal and only noticable if you have a ride that is already stiff? Or is this something unique to Konis?
Old Mar 15, 2007 | 12:46 PM
cpvdh's Avatar
cpvdh
i think that the oil is designed specifically to withstand the normal operating temperature range, that is it shouldnt change much from cold to warm
more likely it is a combination of cold bushing and cold tires
the rubber reacts much more to temperature change, and is not as forgiving, thus a more jarring ride and less smooth response
but i may be wrong h:
Old Mar 15, 2007 | 01:47 PM
Spec R's Avatar
Spec R
yes, its common that some shocks are stiffer when its cold. i asked this topic many years ago, but i forgot where the links were.
DB Squad
Integra Forum Moderator
Old Mar 24, 2007 | 08:49 PM
stumpyf4's Avatar
stumpyf4
Correct.
