Suspension Suspense
Old Mar 8, 2007 | 10:13 AM
95GSRGuy's Avatar
95GSRGuy
Kittenpurr Banshee scream
Thumbs-up jesusublime99!
Old Mar 9, 2007 | 04:46 AM
fjm1's Avatar
fjm1
G35
Originally Posted by 95GSRGuy
So it sounds like I can get that 1" drop w/Konis only? Or Konis & new springs combined?
Koni's on lowest adjustment is good for maybe 1/2 inch - 3/4 inch
Anything beyond you will need different springs.
If you do a combination Koni Yellows and the highly regarded GC springs you can then adjust the spring perch on the Koni's to the ride height you like.
Old Mar 9, 2007 | 07:46 AM
95GSRGuy's Avatar
95GSRGuy
This has all been great info and my direction is taking shape. I can't help but be impressed with the high regard shown for the Ground Control coilovers w/ Koni yellows. It sounds like a top-quality product that will give me the look that I want, avoid needing an alignment kit, improve handling to a degree and maintain reasonable comfort. Am I right so far?
So I noticed that the GC's are available with a 0"-2.5" drop, or a .5"-3.5" drop. Would the 0-2.5 be my best option, since my goal is a 1" drop?
In parallel, I've been enjoying jesusublime99's thread about choosing a GC custom spring rate. This is what I've learned so far:
Dave: 448F/336R
Difussion3: 350F/400R
bnuk: 400F/400R (very bouncy in back!)
Das Schmoo: 350F/450R (not for everyone!)
jesusublime99: 440F/360R
james3232: 350F/400R
recommended for me: 380F/250R
That's quite a wide range of choices! Since the weight distribution on our cars is 64/36, I would think that a higher rate in the back is a very specialized application, indeed. If the standard (I believe Eibach) rates included on the GC's are 380F/250R, would that be my best option to start with?
Thanks again guys for all your help.
Old Mar 9, 2007 | 08:38 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you want to dish out the money for the Koni Yellow/GC setup, I guarantee you will not be disappointed, regardless of the spring rate you choose. A lower spring rate will allow a wider range of stiffness adjustability on the Koni Yellows. With a higher rate, you must run the shocks almost full stiff to avoid bouncing around like crazy.
For a lower cost alternative to the Ground Controls if you don't necessarily want or need the ride height adjustability or custom spring rates is pairing a set of Type R springs on the Koni Yellows instead. You could pick up a used set of springs for less than $100 and it will offer a subtle drop that could be adjusted to around 1" just messing with the spring perches on the Koni's.
Here is a DIY walkthrough in which he is using ITR springs on a set of Koni Yellows. You can also get a sense for how the perches work if you wanted to go that route.
Old Mar 9, 2007 | 09:41 AM
95GSRGuy's Avatar
95GSRGuy
Schmoo - You are a wealth of information, as well as a gentleman and a scholar. This does indeed give me a very viable alternative. I will ponder all of this....
Old Mar 9, 2007 | 12:39 PM
jesusublime99's Avatar
jesusublime99
95GSRGuy,
Its great to see how you are researching in-depth with and asking questions with an open mind before you purchase. Good luck with whatever setup you choose.
Old Mar 9, 2007 | 06:39 PM
Provocateur
On permanent hiatus
I try.
Like jesusublime99 said, it is encouraging to see a new member come to this board asking questions clarifying research he had done beforehand. I believe you have more than enough knowledge at this point to make a smart decision on a suspension setup.
Like I said before, it just comes down to how much money you want to spend. Any decent spring paired with Koni Yellows is going to make for a well balanced car that will handle significantly better than stock.
Good luck.
Old Mar 10, 2007 | 08:37 AM
95GSRGuy's Avatar
95GSRGuy
My thanks to all for your help, and especially jesusublime99 and Schmoo for your kind words. Now I can get down to some serious planning....
