B20 crank in a B18?
I'd hit it =P
yeah thats 6mm of height difference.
So if anything Im better off with a B18B crank in a B18C block? Im planning on Wco or Eagle rods & pistons to up the compression anyway. Theres a JE set thats 12.4:1 with Carrillo H beam rods for like $1100. Good deal? heres the link.
http://www.importperformanceparts.net/
PS- Yeah i dont even know why they call it a B series. It has NOTHING in common with the b series family.
been there done that
I'd hit it =P
Well theres only 200 bucks difference in price. Might as well. Then later on if I wanna boost it then I can. Only drawback is I'll have to go with at least stock compression if not less unless I do like 5psi but that might be too much for 12.4 compression. Thats just a good way to burn a piston.
Apathy Kills
12.4:1 CR? :eek4:
If that math is correct, that's seriously pushing it for pump gas.
I would consider 10.5:1 your practical limit if turbocharging is ever going to come into the equation... possibly 11.0:1 if you've got a competent tuner and you're sleeving your block.
12.4:1 CR? :eek4:
at that CR id be really skeptical about running pump gas in your car man.
im with dave 110% on this one
meh, 12.4:1 is doable on pump gas. you just need cams with lots of duration to bleed off some of that static compression.
but i'd keep it safe and sane in the 11:1 territory.
I'd hit it =P
cool, I'll look into it and see what i can find thats doable. I figured 12.4 is ok with 93 octane which I run in it now. Am planning on a set of cams anyway so I guess I just need to pan out a good setup. Snoop you said a longer duration cam would help? So what kind of lift would be good?
I'd hit it =P
Well I got to the bottom of things... literally... just waiting on a set of bearings at the moment. I was surprised how it didnt take long at all to get it all torn down.
