stupid check engine light
Old Feb 16, 2007 | 03:28 PM
JKAE's Avatar
JKAE
2000TEGLS4DR
Default stupid check engine light
2000 teg ls-just did the timing belt-water pump. check engine light came on and
im getting p0170 system too rich bank 1-found o2 sensor plug is busted so i changed that and i changed the fuel pressure regulator but i still get this code.
any ideas???????
Old Feb 16, 2007 | 03:40 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Did you reset the ECU by disconnecting the positive battery lead for 5 minutes? If not, you ought to.
Also, if you still have your OEM CD deck... make sure you have the anti-theft code before disconnecting the battery.
Old Feb 16, 2007 | 03:53 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Only reason why your CEL is still on is because you haven't reset it yet. Why did you change the FPR?
Old Feb 18, 2007 | 06:17 AM
JKAE's Avatar
JKAE
2000TEGLS4DR
I reset the light with my scanner. I changed the FPR because I was having a hard start in the morning and I did a vacuum test on it and it was bad. I still have cold morning start though. The light hasnt come on but I think it will. It was code p0172 not p0170
Old Mar 16, 2007 | 07:24 PM
JKAE's Avatar
JKAE
2000TEGLS4DR
still getting codes p0170 fuel trim malfunction bank 1 and p0172 system too rich bank1. any one with any ideas????????
fuel pressure reg is new
iac motor new
o2 sensor new
im lost on this one???????????????
Old Mar 16, 2007 | 08:05 PM
2001TEGGSR's Avatar
2001TEGGSR
Did you replace the pre-cat o2 sensor, or the secondary? I would double check the wiring if it wasn't a plug and play sensor. Also consider checking your timing belt, you may have advanced or retarded one of the cam sprockets.
If your positive all that is good, it might be the TPS sensor or a faulty fuel injector.
Old Jun 4, 2008 | 12:41 AM
integraRS-94's Avatar
integraRS-94
Default need help
i need to know where is the location of the plug/socket in my teg. 94 in order to attach it to the scanner. please help my engine indicator is on.
Old Jun 4, 2008 | 04:53 AM
2001TEGGSR's Avatar
2001TEGGSR
The diagnostics port is located under the dash, behind the center console on the passanger side.
Old Jun 4, 2008 | 12:19 PM
whatinthe's Avatar
whatinthe
The Duke of Earl
Its closer to the kick panel on te passenger side
Old Jun 5, 2008 | 09:07 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
2001TEGGSR is correct.....it's directly behind the center console on the passenger side......the ecu is the one by the kick panel.
