Start up problem....
Old Jan 28, 2007 | 03:24 PM
doobiexx928xx's Avatar
doobiexx928xx
B18 Bullet
Default Start up problem....
It started happening this morning when i went to start my car it wouldnt stay on... It starts for a short second and turns off... I have to push the gas pedal 3/4 of the way in, in order for it to start... Is there something wrong with the F.I. or the gas pump?
Old Jan 28, 2007 | 04:06 PM
teg92's Avatar
teg92
WHAT OK YEAH!
could be a few things, fuel pump, or main realy,
Old Jan 29, 2007 | 08:23 AM
doobiexx928xx
B18 Bullet
Damn... Now The fuel pump doesnt work. I can't hear turn on when I turn The key... I looked at the main relay but how do I check to see i f it still works? Any help is appriciated.. Thanx
Old Jan 29, 2007 | 02:21 PM
2001TEGGSR's Avatar
2001TEGGSR
Does it run alright after you get it warmed up?
Old Jan 29, 2007 | 03:43 PM
doobiexx928xx
B18 Bullet
Fix it! It was the contacts on the key cylinder... sandpaper did the trick... Once again Thanks for all the input guys :bigok: Now time for a doobie :bandito:
Old Jan 30, 2007 | 07:54 AM
bnuk's Avatar
bnuk
interesting, what made you look there and how did you get sandpaper in there?
Old Jan 30, 2007 | 04:33 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I'm having the same issue. I think my issue is related to my ECT sensor CEL that I've had for a while now. Replaced the sensor and still no luck. Still throwing the code and still having the same problem. It usually starts and stays running after a few minutes of messing with it though. :shrug:
Old Jan 30, 2007 | 04:39 PM
doobiexx928xx
B18 Bullet
Well I had it fixed yesterday, BUT... A short while ago it turned of on me while I was driving!!! There is two metal plates that turn when you turn the key. When the car is running, It gets knock out of the ON position and goes into ACC, So the car turns off.
