Resonation @ 3000 RPM
Old Jan 19, 2007 | 10:20 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
Default Resonation @ 3000 RPM
OK I have been having this weird problem for some time now and despite every attempt to isolate it I have been unsuccesfull so I am turning to the knowledge base here for some help. This has been happening for over a year and is more an annoyance than anything.
Every time I hit 3000 RPM when the engine is at normal operating temperatures I hear something vibrating. This does not happen when the engine is cold, only when it is warmed up and only happens at 3000 RPM. I do not feel anything when driving the car or have any vibrations in the steering wheel or elsewhere. If it were not for the fact I hear the vibration at 3000 RPM I would not know it was there as the car runs normal.
A little about the car...
    If anyone has any ideas float me a bone...
    Thanks,
    Old Jan 19, 2007 | 10:37 AM
    Provocateur's Avatar
    Provocateur
    On permanent hiatus
    Does it sound like exhaust or heatshield rattling? There is a known problem with the A pipe on most GSR's that cause a rattling right around 3k rpm.
    https://www.honda-acura.net/forums/s...haust+rattling
    Old Jan 19, 2007 | 11:36 AM
    GSRRacer95's Avatar
    GSRRacer95
    Fight On!
    Mine does the same thing and I have an aftermarket exhaust.
    Old Jan 19, 2007 | 11:42 AM
    DVPGSR's Avatar
    DVPGSR
    I need sleep...
    Schmoo, thanks for the link. From the sounds of it that seems to be it, the A-pipe. I checked the heat shields more than once so I would be suspect if it was them.
    Now I have justification to get the I/H/C/E I want for the car...
    Old Jan 19, 2007 | 11:53 AM
    Buyimports2's Avatar
    Buyimports2
    3000rpm is resonance for a crapload of things on our cars. Most likely something the size and shape of a heat shield.
    Old Jan 19, 2007 | 11:54 AM
    Provocateur
    On permanent hiatus
    Yes, I recommend checking the tightness on all the heatshields, but it is most likely a cracked weld in the A-pipe. Back when my car was stock, it had the same problem.
    Old Jan 19, 2007 | 01:00 PM
    DVPGSR's Avatar
    DVPGSR
    I need sleep...
    I have checked them every time I do an oil change and they are fine.
    Old Jan 19, 2007 | 01:03 PM
    Snoopy's Avatar
    Snoopy
    been there done that
    if you've done that and still have the stock header, i put my money on the cracked weld in the a pipe.
    Old Jan 19, 2007 | 02:05 PM
    DVPGSR's Avatar
    DVPGSR
    I need sleep...
    Agreed...now it is time to get a new setup.
    Been thinking about a JDM ITR 4-1 intake and an Apexi WS exhaust, just need a CAT.
    Old Jan 19, 2007 | 02:23 PM
    Snoopy's Avatar
    Snoopy
    you can have your stock cat modified with a 2.5'' collector flange but it wont be the nicest flowing thing
