Well I can get an ITR engine for bout 3500, and install myself. =D
It's just which is better for me.
I want good throttle response and good power, nothing HIGH BOOST, just wanna run around 400ish H.P. Maybe even 370 h.p
Buy a gsr motor!! easier to tune, you will probably get closer to 400hp with that block than a type R block both running with stock internals just do to the C/R!!
Forged pistons & rods, Bore & hone for a fresh surface. At the same time, replace the valve guides, stem seals, and all other gaskets. Looking at around 2k. You could easily make 400+ WHP
FooD are you serious man, ITR motor for 2K-3K , mine was over $6000 from inlinefour.com, i got the 98' Spec and also asked for an ITR sway bar which with shipping came out to $6800, i got lucky and my uncle installed it for free during a week off from work. so the numbers will be $5000-$7000W/Install.
You obviously do not live close to mexicans and Tijuana.
