suspension noise HELP
Old Oct 4, 2002 | 03:59 AM
90'RS's Avatar
90'RS
Default suspension noise HELP
I recently lowered my car with KYB GR-2 shocks and H&R OE Sport springs. My thing now is when I hit bumps on the driver side of the car, in front, it makes a noise like if something is loose but I made sure everything was tightened back down. Do any of you what this could be? Plus the noise doesn't happen all the time.
Old Oct 8, 2002 | 05:52 PM
Creep's Avatar
Creep
Are they progressive springs? the coils might be clanking.
Buy some silencer tubing from honda...or make your own w/ rubber hose.
Old Oct 8, 2002 | 07:17 PM
g2tegls's Avatar
g2tegls
MR, ftw
After I put springs and camber kit in I would get a clunk noise when I started and stopped. It went away after I got an alignment. I dunno if that's what fixed it but it stopped. HTH :dunno:
Old Oct 8, 2002 | 08:00 PM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
Do you have a camber kit on your car?
Old Oct 8, 2002 | 09:19 PM
JackoliciousLeg's Avatar
JackoliciousLeg
root
I had the same thing happen, and it ended up being my front sway bar...
Old Oct 9, 2002 | 03:42 AM
90'RS's Avatar
90'RS
I don't have a camber kit on because it should not need it because it's only 1" drop. I go to align it today so I hope that takes it away but it doesn't do it when I stop and start. They are also progressive springs so I will check into that thanks. Thanks for all the good ideas guys.
I have the H&R OE springs with GR-2 shocks if this helps with any ideas.
90'RS's Avatar
90'RS
What was wrong with the front sway bar???
