erradic idle
Old Dec 28, 2006 | 02:55 AM
perrotto's Avatar
perrotto
B18C1
Default erradic idle
When my integra is cold, it starts out around 2000 rpm. Then as it warms up, it settles down to just under 1000 rpm. Today it stayed up around 1500ish rpm so I tapped the gas to see if it would bring it down. That's when the needle started fluctuating from 1000 to just under 2000 rpm. Any thoughts...???
Old Dec 28, 2006 | 06:14 AM
carta79's Avatar
carta79
Life after death
Idle air control valve or fast idle thermo valve, I would bet it's one of the two.
Old Dec 28, 2006 | 07:24 AM
perrotto's Avatar
perrotto
B18C1
Thanks...Are those parts hard to install?
Old Dec 28, 2006 | 01:46 PM
jesusublime99's Avatar
jesusublime99
Only 94-95 integra throttle bodies come with Fast-idle thermo valves. You have a '96, so you can try removing the Idle Air Control Valve from the intake manifold and cleaning it thorughly. It is located on the backside of the IM, close to the firewall. I think you can use break parts cleaner. If that does not work, let us know.
Old Dec 29, 2006 | 05:52 AM
carta79's Avatar
carta79
Life after death
I didn't know he had a 96'. :dunno:
Old Dec 29, 2006 | 09:23 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
I Have The Same Problem With My 95. Ive Changed The Iacv And Fitv, Still There Is A Problem.
Old Jan 2, 2007 | 02:38 AM
perrotto's Avatar
perrotto
B18C1
Thanks, I'll try to clean it. I won't be able to reply for about six months. I joined the Army Reserve. I ship out on the fourth...:usa:
