stroker kit
Old Nov 2, 2006 | 08:05 AM
dooday08's Avatar
dooday08
Banned
Default stroker kit
i have a 95 teg special edition and i was wondering if putting a stroker kit in it was a good thing to do and advantages and disadvantages?
Old Nov 2, 2006 | 11:13 AM
Snoopy's Avatar
Snoopy
been there done that
increasing the stroke increases displacement. personally, i would rather sleeve and overbore for more displacement.
Old Nov 2, 2006 | 12:29 PM
primetime's Avatar
primetime
[QUOTE=dooday08;3207964]i have a 95 teg special edition and i was wondering if putting a stroker kit in it was a good thing to do and advantages and disadvantages?[/QUOTE
you will need LSD to get that power to the ground!!!
Old Nov 2, 2006 | 02:02 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
[QUOTE=primetime;3208429]
LSDs won't hurt to have, but he won't NEED it. I don't think you would be able to rev as high as you normally would if you stroke the B18 to say 2.1 liters. Thats just about the only disadvantage I could think of and I don't even think that could be true. Advantages would be more torque in the low end.
Old Nov 2, 2006 | 02:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What are your goals?
Unless you are pretty much fully built N/A, you won't benefit much at all from a stroker kit. It will give a little bit of torque down low but the increased stroke/rod ratio will limit revability.
If you are looking at increasing displacement, Snoopy hit the nail on the head. If you are looking for some extra power, consider a vtec head swap or some valvetrain work with high compression pistons.
Old Nov 4, 2006 | 01:22 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
A lot of guys actually stroke thier built motors when running insane amounts of boost. Since the turbo won't start spooling until about 4500ish they can have some low end to make up for the laggy turbo. That sounds right, right?
Old Nov 5, 2006 | 01:10 AM
2001TEGGSR's Avatar
2001TEGGSR
Especially with boost, I would think that a longer rod/stroke ratio would be the most inefficient way to increase displacement. Even if your engine is sleeved, bored to the max, and running high boost - I doubt the gain would be worth it. Unless your funds are endless of course.
