pistons
Old Oct 31, 2006 | 05:58 PM
honura's Avatar
honura
Seni
Default pistons
Hey what do you guys think about these? Good or shit?
http://cgi.ebay.com/ebaymotors/JDM-C...41930479QQrdZ1
Old Oct 31, 2006 | 06:07 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
FooD2000 is using a set of OE replacements made by Nippon. I am using their piston rings. I haven't heard any negative criticism about them.
Old Oct 31, 2006 | 08:22 PM
2001TEGGSR's Avatar
2001TEGGSR
Personally, I wouldn't use anything but OEM rod & main bearings.
The nippon bearings are most likley similar to ACL or King, which only offer one size for a standard (non machined) crankshaft. While I am sure the minor difference in oil clearance wouldn't harm everyday operation, there's a reason honda is so percise with their thickness. Balancing, Oil Pressure, etc.
When your car was assembled, they match the sizes below to every journal, in order to fine tune a percise oil clearance. Most aftermarket bearings are the same as OEM green size, which is the most universal to every application.
You could just take the crank and nippon bearings into a machine shop and have them match the journals to the bearings, to achieve OEM like results.
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
If you already knew this, then disreguard. I just wasted money having a crank re-ground, and couldn't achieve OEM type results with oversized bearings. Just trying to save you a headache.
Old Nov 1, 2006 | 08:52 PM
FooD2000's Avatar
FooD2000
Still Water
If that ebay link is to those nippon piston / rings set for $140 shipped... mine are on 1,800 miles and still going. so we'll see.
Old Nov 1, 2006 | 09:34 PM
2001TEGGSR's Avatar
2001TEGGSR
it is for:
NEW NIPPON RACING PERFORMANCE B SERIES CTR PISTONS
NEW NPR PERFORMANCE NITRITE COATED RINGS AND WRIST PINS
NEW NIPPON RACING MULTI LAYER STEEL HEAD GASKET
NEW KING HIGH PERFORMANCE SILICON COATED ROD AND MAIN BEARINGS
NEW OEM HONDA OIL FILTER WITH CRUSH WASHER
NEW KING PERFORMANCE THRUST WASHERS
I'd trust everything but the bearings, but thats just me...
Old Nov 2, 2006 | 05:25 AM
honura's Avatar
honura
Seni
So what bearings do you guys recommend? I tend to be a little child and beat on the motor a whole lot! I really don't like hitting past 7900rpms 8 outta 10 times. But I was thinking going turbo. But I got into my cusins 92 si K20 and man for an all motor car its enjoyable. IDK
Old Nov 2, 2006 | 06:20 AM
2001TEGGSR's Avatar
2001TEGGSR
Either way, OEM bearings only.
It's not the quality of the after market bearings that concerns me, it's the fact that they only make one size for a standard crankshaft. Honda calls for an array of the sizes above, depending on the engine.
Traditionally, and still for most other engines, there is only one standard sized bearing. They step up in increments of .010", for a re-surfaced crankshaft. You really need all the sizes above available in order to get the precise, even oil clearance honda calls for.
You won't know exactally what size OEM bearings you need, until you pull the oil pan at least. You use codes on the crankshaft and block, match them to a chart in the helms and order bearings accordingly.
Old Nov 2, 2006 | 12:33 PM
FooD2000's Avatar
FooD2000
Still Water
wait... so are you considering rebuilding your engine for FI now?
Old Nov 2, 2006 | 12:57 PM
honura's Avatar
honura
Seni
Well Im still iffy about the whole turbo only because I feel better in an all motor car. Raw Power!
Old Nov 2, 2006 | 02:41 PM
2001TEGGSR's Avatar
2001TEGGSR
Well, what kind of power goals do you have? Did something happen to your engine that your considering an overhaul? I'd try and decide which route you want to go, before ordering those slugs.
