Acura Integra
Old Oct 22, 2006 | 08:28 PM
anup_anju's Avatar
anup_anju
Default Acura Integra
My car gives smoke( steam?) from underneath the radiator when heater is on . A/C works fine, without any smoke.If heater core leaks, shouldn't the steam come from closer to the hood?coolant level reduces with heater,not with A/c.Where could the leak be? Thnx
Old Oct 23, 2006 | 01:27 PM
2001TEGGSR's Avatar
2001TEGGSR
The heater core is located on the interior side of the firewall. If it was leaking, you would have coolant on you're carpet. I dont understand why its only steaming when the heater is on. Did you check the lower hose? Or the radiator itself?
Old Nov 9, 2006 | 12:11 PM
Wild97integra's Avatar
Wild97integra
When my heater core blew I would have this almost clear color smoke with the nastiest smell leak out from under my hood.
Old Nov 9, 2006 | 01:29 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
Stock radiator ends are plastic and over time can crack. My guess is that you have a small crack in the bottom of your radiator.
Old Nov 9, 2006 | 06:04 PM
VPUPPY's Avatar
VPUPPY
Check the coolant lines that run to the heater core(the ones that run into the firewall on the passenger side) for leaks.
