radiator replacement
Old Oct 9, 2006 | 12:00 AM
R_Squared's Avatar
R_Squared
LEVEL UP
Default radiator replacement
So my OEM radiator has started to leak a bit around the plastic endtanks. I searched here on HAN for a bit and found that a lot of people have gone with radiatorbarn.com for replacements. Is this a reputable site? It looks like they have an OEM style aluminum w/ plastic endtanks replacement for $95 shipped. Is this worth getting or should I look somewhere else?
Old Oct 9, 2006 | 03:04 AM
MTEng's Avatar
MTEng
I've used their radiators before... they seem OK. I got one for my '86 Toyota beater because I wanted to go cheap... it was a "universal fit" for both manual and auto trans cars... it came with the internal trans fluid cooler for auto trans...my car's a 5-speed. Works great, though.
Old Oct 9, 2006 | 07:47 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Most shops can slap in a factory re-man. for 150-200. Which is what I did, so I knew I was not getting cheap shit.
Old Oct 9, 2006 | 09:55 AM
2001TEGGSR's Avatar
2001TEGGSR
I've actually heard good things about the ebay special radiators. h:
IM partial to theese: http://www.performanceradiator.com/
Or theese are good Pirce: http://www.honda-tech.com/zerothread/1771036
Old Nov 4, 2006 | 07:45 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I'd like to go ahead and order one here in the next couple days..Any suggestions for where to look on ebay? It'd be nice if anyone knew of sellers/ebay stores that are reputable. Thanks.
Old Nov 4, 2006 | 08:19 PM
Llamaguy's Avatar
Llamaguy
The second link looks awesome, but I don't know how much it would be worth it since you seem to not want to keep the car for awhile.
Old Nov 4, 2006 | 08:22 PM
AJē06's Avatar
AJē06
Hmmm
I just replace mine, OEM, and its all ok for now. Install it urself it isnt hard. But Id recommend the aftermarket ones if ur gonna do anything else bisides normal driving.
Old Nov 4, 2006 | 08:29 PM
Driverman5777's Avatar
Driverman5777
only problem with that is that until I do my 5 speed swap... I have to also purchase a transmission cooler... Where would a good mounting location be?
Old Nov 4, 2006 | 09:33 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Originally Posted by TI member
I ended up having to make an aluminum mount to mount the a/c condenser fan onto the front side of the condenser, it was simple and took about an hour to fab/mount. I ended up trimming about 1/2 to 3/4 of an inch off of the pass side cooling fan shroud on the side closest to the header so i wouldnt have to worry about it getting hot and melting. No major fab work and basic install done with basic hand tools.
Yeah, I don't think I'd mind spending that much...It's more of the fact that I'd have to mod it. I want one I can just swap in without too much effort. :hs:
Old Nov 4, 2006 | 09:43 PM
Driverman5777
How much of a difference does the performance rad make?
